Re: New 460 Owner-Lots of Q's
Posted by Marksd on April 08, 2006 at 19:15:46 from (70.57.235.14):
In Reply to: New 460 Owner-Lots of Q's posted by marksd on April 08, 2006 at 13:35:15:
I know I asked about the RPM, if you were driving down the road in 5th, whats the max rpm you can run. I think my guage says 2200 but like I said before I thought I read rated is 1850. Can you just run them where ever the throttle can go to not past the 1850? Thanks
Oh speaking about the 5th gear. Is it normal for it to seem like it takes alot of riding the clutch to get going in 5th gear?
Oh can the clutch be adjusted also. I have to let is almost all the way out before it grabs.
Man the more I talk the more I think of questions.
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
