Re: New 460 Owner-Lots of Q's
Posted by Janicholson on April 09, 2006 at 09:13:17 from (66.173.50.86):
In Reply to: Re: New 460 Owner-Lots of Q's posted by Marksd on April 08, 2006 at 19:15:46:
Do not worry about going over the rated 1850 RPM, that speed is the maximum rated speed for torque/horsepower. Usually the result of running wide open, and using the tractor on a load that draws it down to that speed. Start in fifth with the TA back, get up to speed in fifth TA, then ---without pushing the clutch in----, move the TA lever briskly forward, not slowly. This should make it much easier to reduce clutch slippage, because the TA is a clutch driven 2 speed system. If the TA is not working, this will point that fact out. If the tractor does not move in fifth TA, the TA is broken, and needs repaired. (do not use the TA if it fails this test) The TA, when engaged (back) is free wheeling, do not let the tractor go down hill freely with the TA back it may overspeed the TA and wreck it, and it is dangerous. If you here a whining noise like a jet starting, from the trans area, you may be overspeeding the TA. The TA is marvelous learn to use it (and read info from the archives here) The clutch should be adjused (linkage on rods) so that it has about 3/4" to an inch of free play between the pedal stop, and the platform casting. This is a ball park size, the manual will have exact specs. JimN
Home
| Forums
| Order Support
Today's Featured Article -
Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac
... [Read Article]
Latest Ad:
2555 Mahindra Shuttle 4x4 heat,air,diesel,7ft Mahindra heavy duty bushhog 7ft snowblade bucket
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
