Re: New 460 Owner-Lots of Q's
Posted by Janicholson on April 09, 2006 at 20:51:12 from (66.173.50.171):
In Reply to: Re: New 460 Owner-Lots of Q's posted by Marksd on April 09, 2006 at 15:59:15:
It will whine some no matter what.
The hydraulic system should be checked with a high pressure gauge, and a flow rater (meeter that shows flow rate. Do check the fluid level From the book.
The TA is a Planetary gear set with two clutches, a TA clutch, and a Primary (regular) clutch. It also has a overrunning (one way clutch that looks kinda like a roller bearing). If the TA clutch is out, or the one way clutch is bad, it will not pull a load in TA position (it may kinda work with no load in low gear, or second, or from no TA to TA in any gear till a load is placed on it. I would get it repaired, The TA is a fine feature and "makes" the tractor way more flexible and handy. It may cost a bunch if all is done by others. Or you can have an adventure. (requires splitting the tractor into three pieces).
Getting a book is the most important thing you can do. From here, or binder books, or Ebay.
Keep in touch,
JimN
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
