Re: New 460 Owner-Lots of Q's
Posted by Marksd on April 09, 2006 at 15:59:15 from (70.57.235.14):
In Reply to: Re: New 460 Owner-Lots of Q's posted by Janicholson on April 09, 2006 at 09:13:17:
JimN, Is teh TA an extra set of gears or just a clutch? Like is 1st gear it goes real slow with the TA engaged (back to the rear, right?). The once you push it forward the tractor feels like it jumps into fast gear or something. I tried the TA in 4th and 5th and it really didn't move the tractor. So is the TA bad? I was watching the clutch linkage and I noticed down by the trans case the linkage has bolts in slots then move. So when you enage the TA it looks like your not really moving much on the linkages. Is that normal? The TA doesn't use any of the hydraulics do they?
Also the clutch looks like I can push it in about 1 inch before it starts to take it out of gear. Is that normal?
If the TA clutch is bad is it a big job to change?
Today's Featured Article - Old Abe is Still Making Hay - by Jeremy Sweeten. Things have changed a bit since my last article. I am now almost finished graduate school at Purdue University. I am still in Agronomy, but specializing in hay and forages. My wife has survived two years of marriage to a part-time farmer. The equipment line up has changed a bit too. The DC has retired to ... [Read Article]
