Re: Farmall 340 Not Starting
Posted by Larry Hardesty on July 24, 2006 at 20:11:47 from (70.96.154.152):
In Reply to: Re: Farmall 340 Not Starting posted by Larry Hardesty on July 24, 2006 at 19:55:54:
Hall, Read directions again and said "for 6-cylinder engines, use present reisstance unit." I misread and thought for 6 volt. Well, my 340 is 4 cylinder. Don't understand why I would need resistance unit on a 12 volt coil on a 6 volt tractor.
Well, color me confused!!
Larry
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
