Re: Farmall 340 Not Starting
Posted by Larry Hardesty on July 26, 2006 at 17:32:33 from (70.96.154.152):
In Reply to: Re: Farmall 340 Not Starting posted by El Toro on July 26, 2006 at 17:14:43:
Hal, Well, Bigdog of the Farmall Tractor listserve has helped me make some progress and figure out it is not the coil. I took the old coil and old condenser in Case-IH. The old condenser is bad, which probably was the start of the program. They could not test the old coil. I took it to local O'Reilly's Auto Parts place. The kid there tried but neither of us new much about testing a coil, but it looked good. When I got home Bigdog has recommended connecting a test light between the coil + terminal and a ground and cranking the tractor. If everything was working right, the light should go on and off as I cranked the tractor. It did not. My thinking now is I have a ground. I will take out the new coil I put in and test it and then put it back without twisting the wires as much. Anyway that is progress as of 7:30 p.m. today. Good new is new appears not to be the problem. Larry
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
