Re: Farmall 340 Not Starting
Posted by El Toro on July 25, 2006 at 04:08:20 from (64.12.116.65):
In Reply to: Re: Farmall 340 Not Starting posted by Larry Hardesty on July 24, 2006 at 20:11:47:
If your battery is 6 volts you do not need a 12 volt coil. You need a 12 volt coil if your battery is 12 volts or you would need a ballast resistor if you are using a 6 volt coil when using a 12 volt battery. These are used to drop the voltage to 6 volts so your points don't burn up.
Is your battery 6 volts? If it is it should be
+ positive grounded and your small terminal on the
coil with + positive sign should be wire to your
distributor. Make sure the rotor is clean and doesn't have any carbon on it. Check those wires
at the points and make sure they're not touching
the distributor body. This would ground out the points. Where are you located? Hal
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
