Re: Farmall 340 Not Starting
Posted by Larry Hardesty on July 24, 2006 at 19:55:54 from (70.96.154.152):
In Reply to: Re: Farmall 340 Not Starting posted by El Toro on July 24, 2006 at 10:50:37:
Hal, Well, I put the coil on. I get juice from negative to positive terminals on the coil when the switch is on. I had that with the old coil.
However, I am still not getting juice out of the coil. Even tried a new cable from the coil to the distributor. I cranked the tractor with the cable end near the frame...no spark.
Now the directions say for this coil to "use present reistance unit." I do not see a resistance unit. Is this the problem now?
There is a single wire from the generator to the coil. However the directions with the coil show a black and a white cable with a black cable to one end of the resistance unit and then a write wire connecting to the other end going back and connecting to the positive terminal, along with with a white cable from the generator. Probably not all clear.
Sorry to be a bother, but this has me stumped.
Larry
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
