Re: Farmall 340 Not Starting
Posted by El Toro on July 25, 2006 at 07:19:50 from (205.188.116.133):
In Reply to: Re: Farmall 340 Not Starting posted by Larry Hardesty on July 25, 2006 at 05:28:57:
If you have voltage at the points with the switch on, you should see spark from the points if you snap them open and closed a few times. I would install another condenser to see if that's the problem. Hal
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
