Rats! PTO quit on 856
Posted by JWCarp on July 30, 2013 at 20:12:42 from (67.142.163.26):
I was baling hay tonight with the 856. Last couple of times I started a bale I noticed it did not start up like it normally does. I had to pull the handle up further. It ran fine. I tied a bale, shut it off, dumped the bale and it would not start up. I don"t under stand how it could be working fine and then not start back up. Is it most likely a valve problem. I guess I will have to get the book out and see where to check the pressure.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
