check oil, then check pressure down under the piviot for the valve through the hole in the bracket that holds the linkage there is a plug you will need a special fitting from your friendly dealer for about 30 dollars then screw in gauge. It should read about 160-240 depending on the tractor model. I would set it at the 200-240 figure. The valve will come out the bottom without pulling the unit. There is a plug there you will need to either face it down hill or drain the oil though.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
