As urbancase said in his post below, it may be the tiny connector pin has broken. If it is, you take the valve out the bottom of the unit. It will require removing some of the hitch stabilizer parts but otherwise it is rather simple. For the tiny pin I used a needle bearing roller from a U-joint cross and bearing. I found one that was the same diameter as the hole in the valve parts it connects through and then ground it on a bench grinder to the needed length. Saved a trip to the dealer. Has worked perfectly for many years. Pin is item #27 in diagram
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
