Posted by Cat u9 u9 on September 09, 2012 at 19:46:03 from (76.250.157.220):
How do you figure out were the psi coming from If the radatior is blowing all the water out I've been fighting this old cat 1961 17A It's plenty strong but won't run cool New radatior Cleaned out heat exchanger Rebult water pump New complete heads an gaskets It had a pony motor put on a starter New turbo and exhaust All this with in a year she was running good But stated getting hot more an more Figured it was pre com r head gasket Head gasket was blown replaced w/everything New got the hook up but it didn't fix it I'm thinking of making it into a steam dozer
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
Looking 4 set 9 bolt hubs 3 1/8 inch to fit 60 to 4010 jd
[More Ads]
