Posted by Uncle Ernie on September 09, 2012 at 20:13:03 from (64.38.158.32):
In Reply to: Blue devil don't work posted by Cat u9 u9 on September 09, 2012 at 19:46:03:
Are you getting coolant in the oil too? On some engines you can take the pan off, presurize the radiator and watch for coolant leaking down from the cylinders. You could make an adapter to go into the injector hole and connect to an air compressor. Roll the engine over to TDC compression stroke, pressurize the cylinder and listen for where the air comes out.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
Looking 4 set 9 bolt hubs 3 1/8 inch to fit 60 to 4010 jd
[More Ads]
