Posted by NCWayne on September 09, 2012 at 20:33:31 from (69.40.232.132):
In Reply to: Blue devil don't work posted by Cat u9 u9 on September 09, 2012 at 19:46:03:
Probably crazy to mention given all you said you've done, but what about the thermostat? Without a thermostat in place, or with the thermostat stuck wide open, many engines will have enough flow going through the radiator to cause water to come out if the cap is off. Even if it's just stuck wide open the lack of restriction in the system will allow the water to flow too fast and not release enough ehat into the radiator and that alone will cause one to heat. So, if you haven't checked or changed it already I'd definately try that.
Anothetr thing to check on the older machines is the pressure regulator on the radiator. Look just to one side of the fill port for a round disc with several bolts in it. If you take it off there should be a spring, a disc, and another thin plate that acts as a seat under it. Make sure that everything is clean and free to move, that the disc and sealing surface are clean, etc, etc. Too make sure the sealing disc on the main radiator cap is good too so it seals. Without these items in place and working properly the radiator will not build any pressure internally, and, like a standard radiator without a pressure cap, it will not cool like it's supposed to.
I read your post below and the seal rings on the liners will allow coolant into the oil, but they have nothing to do with any kind of compression/ pressure getting into the cooling system. In other words the o-rings on the liners shouldn't be an issue unless you start seeing coolant in your oil.
Sounds like you've done and checked alot of stuff already, but those are a few things I would check first if called out to a customers machine, hope they help.
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
