Super c camshaft stripped
Posted by White halftrack on May 28, 2014 at 09:10:32 from (174.230.192.207):
Hello everyone. I bought a non running super c because I am
not smart enough to buy running good tractors. The guy I
bought it from said the camshaft gear was stripped and he
already had bought a new hydraulic pump before deciding to
sell it. I see camshaft gears and camshafts on eBay relatively
cheap. Is there any reason not to just switch it out? Mating or
bore problems?
I know the crank pulley is going to miserable. I will pull the
pan and clean.
Is the reg c cam the same camshaft and gear? I hope the
crank gear is good but will find out. I hope to make this into a
decent belly mower tractor.
Any help is appreciated. Thanks
Today's Featured Article - A Tinker�s Guide to Manifold Repairs - by Curtis Von Fange. A common characteristic of keeping older equipment is that some parts to make repairs can be extremely difficult to locate. For example, finding a replacement for a cracked intake or exhaust manifold on a unique tractor or odd brand can be a frustrating and downright impossible mission. So, what is an alternative solution to scraping out that �one of a kind� piece of history? First, decide if you are one to try a repair yourself or have someone else do it. If you are uncomfortable about ... [Read Article]
