That cam gear is a press fit & you probably need to pull the cam shaft and have it pressed off & the new gear pressed on. You also need to pull the oil pump. Get a good shop manual. Also the grille, radiator & timing gear cover has to be removed. Check that damper pulley for a worn groove in the hub. You probably need a new seal in the cover and a speedi-sleeve to cover the groove in the hub. Hal
Today's Featured Article - Haying Before Tractors - by Owen Clark. Hi guys! At age 8 (1927, am now 79) I was learning how to drive a stacker team on the old homemade A-frame wooden stacker, on three of my uncles` dairy farms in Star Valley Wyoming (south of Jackson Hole, on the Wyoming-Idaho border). There was one steam tractor in the Valley, owned by an entrepeneur who used it to run his grain threshing machine, that he hauled from farm to farm for the fall harvest. We used teams of horses not only on the stacker, but on the buckrake to buck the dried
... [Read Article]
