Well in your picture you have the diode wired in parrel to the wire from the #1 terminal to the ignition switch and if that is so yep it will not work. The diode needs to be in line as in cut the wire under the diode and it will work the way it should. You do also have it hooked up wrong on the coil and you need to have the + side of the coil hooked to the ignition switch and the - side to the distributor
Today's Featured Article - Grain Threshing in the Early 40's - by Jerry D. Coleman. How many of you can sit there and say that you have plowed with a mule? Well I would say not many, but maybe a few. This story is about the day my Grandfather Brown (true name) decided along with my parents to purchase a new Ford tractor. It wasn't really new except to us. The year was about 1967 and my father found a good used Ford 601 tractor to use on the farm instead of "Bob", our old mule. Now my grandfather had had this mule since the mid 40's and he was getting some age on him. S
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
