Bob M or John T, W6 electrical problems
Posted by chadd on March 18, 2007 at 11:13:27 from (4.142.219.92):
Well, we had done the test on the generator where you ground the field terminal again and it began charging when the generator was hooked up with a negative ground. Well I just put another regulator on it, and reversed the terminals back to positive ground and this time I grounded the field terminal and then jumped the batt and arm terminals. I reconnected the field terminal and then when I started the tractor, the ammeter went back and pegged at full drain again. Is it possible for a generator to be permanently polarized? It seems regardless of what I do, it wants to run with a negative ground. However, the regulators are for positive ground. The tractor has never operated in a negative ground condition its entire life. If it pegs at full drain on positive ground and the needle just bounces around with negative ground, is this definitely a generator problem, or could it be a tractor electrical system problem? When the tractor was rewired 15 years ago, the regulator was moved to a perch on top of the generator, so there are no wires that are chafed through. I am running out of ideas here. . . Any recommendations?
Thanks.
Today's Featured Article - Tractors and the City Boy - by Ken. A few years back I came to the conclusion that city life wasn�t for me. The houses so close together you could hear the neighbors fight, traffic so heavy speed limit signs meant nothing. So I started looking for the ultimate country setting. After many months I found the perfect place, off the beaten path, up a private � mile drive, old stone house which has stood the test of time, out buildings which haven�t stood the test of time, trees, birds, rabbits, and snakes. This is the place! Bought ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
