Re: Bob M or John T, W6 electrical problems
Posted by Bob M on March 19, 2007 at 10:03:22 from (151.190.254.108):
In Reply to: Re: Bob M or John T, W6 electrical problems posted by chadd on March 19, 2007 at 07:39:10:
OK � Sounds indeed like the ammeter wired correctly and is working properly. Now I�ve never heard of a generator that �won�t polarize��. I suppose it�s possible but I�ve never heard of it.
Anyway next step is determine whether the generator is at fault or the problem�s with the regulator. Here�s how I�d do it (I�m assuming the wiring is in good shape and properly connected):
1 � Disconnect both wires at the generator. Tape the ARM wire terminal so it cannot be accidentally grounded.
2 � Run a temporary wire from the generator FLD terminal to a good ground.
3 � Take another temporary wire and connect one end to the BAT terminal at the regulator. Then briefly touch the free end of this wire to the generator ARM terminal. (This is to polarize the generator again.)
4 � With the free end of this wire isolated (temporarily tape the end), start the engine and run it at governed RPM. Now take a voltage reading between the generator ARM terminal and a good ground (generator frame). If the generator is working the voltmeter should read somewhere in the range of 15 to 30 volts or so. And assuming the battery positive post grounded, the generator ARM terminal voltage will be negative relative to ground.
If you get a very low voltage reading or if the ARM terminal reading is POSITIVE relative to ground, stop. It's the generator that's messed up. However if the generator output checks out:
5 � With the engine still running at speed, have an assistant watch the ammeter while you temporarily connect the free end of the wire installed in step #3 to the generator ARM terminal. (Expect a spark when you connect�) If the ammeter now indicates a full charge, the generator is OK � the problem is the regulator. However if the ammeter again shows discharge, the problem has gotta be the generator.
Hope this makes sense, and advise what you learn!
Today's Featured Article - Tractors and the City Boy - by Ken. A few years back I came to the conclusion that city life wasn�t for me. The houses so close together you could hear the neighbors fight, traffic so heavy speed limit signs meant nothing. So I started looking for the ultimate country setting. After many months I found the perfect place, off the beaten path, up a private � mile drive, old stone house which has stood the test of time, out buildings which haven�t stood the test of time, trees, birds, rabbits, and snakes. This is the place! Bought ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
