Re: Bob M or John T, W6 electrical problems
Posted by Clip41A on March 19, 2007 at 13:26:24 from (138.29.80.220):
In Reply to: Re: Bob M or John T, W6 electrical problems posted by Bob M on March 19, 2007 at 12:33:41:
Bob and Chad: When I did this on my 'A' a number of years back, I actually had to run the generator as a motor for a few seconds with correct polarity to get it to take the proper polarity. I think the repeated use while it was wired as a negative ground has permanently 'set' the magnets to produce a positive charge at the 'bat' terminals (i.e. negative at the ground, positive at the 'bat'). You can reverse this 'set' by repeated polarizations in the opposite direction (which is what running it as a motor does). I'm working from memory here, but I think you can check the voltage at the 'bat' terminal by disconnecting the 'bat' (charging) wire and using a voltmeter to chekc the voltage at the 'bat' temrinal relative to chassis ground. If you take care with the voltmeter leads, you should read 6 volts at the battery (red to positive, black to negative). At your generator, you should read 8 volts or so at the 'bat' terminal (wire leading to ammeter disconnected). This is again red to positive (chassis) and black on the 'bat' terminal itself. My nickle bet is that you are getting NEGATIVE 8 volts at your 'bat' terminal. if so, polarization is the problem. Good luck, Clip
Home
| Forums
| Order Support
Today's Featured Article -
Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted
... [Read Article]
Latest Ad:
65 Massey FERGUSON DIESEL
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
