Re: Bob M or John T, W6 electrical problems
Posted by Bob M on March 19, 2007 at 07:19:13 from (151.190.254.108):
In Reply to: Re: Bob M or John T, W6 electrical problems posted by chadd on March 18, 2007 at 20:35:21:
Chadd - Have you confirmed the battery is indeed DISCHARGING with the new regulator, and with the battery connected and generator polarized for positive ground? (Check the voltage at the battery terminals with the engine running. 7 volts or higher = charge; 6 volts or less = discharge).
Presuming the battery is discharging, my first suspicion is the problem is the new regulator.
Or (long shot possibility...) inside the ammeter box is there a wire carrying charging current located close to the backside of the ammeter? Reason: The magnetic field surrounding such a wire will screw up the ammeter reading.
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
