12 volt coil
Posted by Robertw on June 26, 2014 at 08:48:01 from (184.8.49.93):
I bought a farmall m that was converted from 6 to 12 volts it has a new 12 volt coil that doesn't require a external resistor that what is says on it the problem is that it's gets hot you can't touch it with your hands hasn't quit yet had it at a pull this week end and the motor run out of power at 156 feet there were some tractors 5 or 6 that was over 200 out of 24 in the class 222 won it this was in the 6500 lbs. class it has 150 lbs. compresson on all four cyl. was wondering if that coil is working right thats on reg. gas thought it should have done better then that runs good
Thanks for any help
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: Super WD9. [More Ads]
