Auction
Re: 12 volt coil
Posted by NNP on June 27, 2014 at 05:03:21 from (66.66.112.196):
In Reply to: 12 volt coil posted by Robertw on June 26, 2014 at 08:48:01:
in addition to what's been said,
put a voltmeter on it while it's running to
check alternator/generator output.
too many volts will mess up the resistance-coil-resistor calculations, and make lots of coil heat.
Since you have the IC14SB, it is probably good to spec.
I'd like to add to SG's post about off brand stuff.
I usually use the IC14SB, but came across some deals on
import 'no resistor needed' 12v coils.
junk, they ohm out much too low.
I labeled them and threw them on the shelf until the next 6 volt tractor comes in.
This post was edited by NNP at 05:04:42 06/27/14.
Latest Ad: Super WD9. [More Ads]
