Posted by Owen Aaland on June 26, 2014 at 19:06:01 from (216.47.32.208):
In Reply to: 12 volt coil posted by Robertw on June 26, 2014 at 08:48:01:
Between the normal operating temperature and heat generated from the engine the coil could get hot enough that you would not want to keep your hand in it. That is about 150° F. An engine under full load is going to running at about 200° F so it is hard to tell if it is overheating by touch. If it is hot enough to boil water it might well be too hot.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
