Next time take a hammer and smack the sides of a tight fitting before you try loosening it. You'll be suprised how much easier it breaks loose. I have hit them just right and just the hammer blow alone would knock the nut loose. yes, on a JIC fitting it isn't uncommon to take the an old fitting apart and clean it up a bit and stop a leak without actualy changing anything. As for your track problem it sounds like you've got alot more wear in the rails than you might think you do. The teeth spacing doesn't change, the change would have to be the distance between the centerlines of the bushings due to the pins being worn out. Wear such at this is the only thing that would make the bushings fall down and fit in the sprocket one time and then be too close together or far apart at another.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
