Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: John Deere 450 Steering Clutches
Posted by Roy Suomi on October 27, 2006 at 19:39:38 from (69.165.41.192):
In Reply to: John Deere 450 Steering Clutches posted by Tweeter on October 27, 2006 at 15:14:08:
Thr jerking is a normal reaction.Thats the way they worked. It wasn't a smooth operating system. The steering is all mechanical . There is a tin cover on top of each steering clutch housing under the seat [ I think 5 3/8 inch bolts on each cover ] With the covers off , you can watch the movement of the linkage..The long 3/8" bolt is the free-play adjustment . Excluding any slop in the linkage, the lever should have about an inch of free-play like any other clutch. Then the throw-out bearing begins to disengage the clutch . After there is some slippage in the clutch, then the brake band clamps around the exterior of the clutch drum causing the track to stop thus steering the machine..Now that we understand the operation of this now's the time to troubleshoot it..In many cases I've seen the clutches wet causing rusting of the clutch disks and plates insude the clutch drum..These machines should always be covered with a tarp from the dashboard over the top of fuel tank to keep water / snow from sitting on top of steering covers..Water can and will get inside through lever bushings and top covers..Inside the top covers you will notice a shorter 5/16" bolt. This is the brake timing bolt. One knuckle there should be Keyed to the shaft and the other knuckle should turn on the shaft.Many times the knuckles are rusted tight and won't operate right.Also in there you will find a 13/16" bolt head standing upright , this is the brake band adjustment. As far as the HLR transmission goes..With the machine off , Listen to the HLR shift detents . There should be a definite click as it shifts into each gear range.If reverse doesn't have this click , look for loose shifter linkage or clevis adjustment that will allow the transmission to shift into full range. I have had to relieve the shifter quadrant with a file to allow the shifter lever to go further than it is supposed to go..If it does click fully into reverse , there might be a pressure problem with the transmission. Look into archives for HLR adjustments..I know I've got a bunch of solutions along with my other learned colliegues there.. good luck
Home
| Forums
Today's Featured Article -
Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
Latest Ad:
Super WD9.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
