Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: John Deere 450 Steering Clutches
Posted by Roy Suomi on October 29, 2006 at 20:41:52 from (69.165.41.192):
In Reply to: Re: John Deere 450 Steering Clutches posted by Roy Suomi on October 29, 2006 at 20:15:00:
If 1 clutchpack works , they should all work unless there's a pressure loss somewhere.There's a " Drum Bung " directly under the floor shifter.If you remove this drum bung plug , there'll be an eighth pipe plug in there on an angle..It should have a 3/16" allen wrench opening in it . Put some grease on the end of the allen wrench and remove the plug[ this will allow removing the plug without loosing it in the hole]..Get a 200 lb gauge and install a flexible grease gun hose on it..It makes for easier reading of the gauge..You might have to extend the end of the hose with a pipe coupling and a 1/8 pipe nipple to clear obstructions in the " bung hole"...That didn't sound right , did it?? Anyhow, read the pressures at half throttle, gear transmission between 3rd gear and 4th gear[ there's a neutral in there . You might have to feel around for it]..Lock the brake pedal down ,Shift the floor shifter into low , high and reverse..Record the pressure readings..Just for giggles, I'll bet pressures aren't any higher than 130 lbs....Should be 165 to 180 lbs..Also when the transmission is adjusted right , you should be able to shift from reverse to high or high to reverse at full throttle without clutching it at all..
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
Super WD9.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
