Crawlers, Dozers, Loaders & Backhoes Discussion Board
Case 580 alternator wiring question
Posted by Gregory Matthew on January 01, 2013 at 16:33:18 from (108.11.46.184):
I have a 580 super e with a delco 3 wire alternator. One of the wires from the two wire connector goes to the battery terminal and the other wire goes into the wiring harness and I'm not us re where it goes.. The alternator tests good but it is not charging. I'm guessing the wire that I can't figure out where it goes energizes the field. None of the dash gauges or dash lights work. Is the "mystery" wire wired to a ight in the dash?
Thanks
Greg
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
