Assume you have a 10-SI. The two wire connector....
Pin 2 from the Batt (The regulator uses this voltage signal to control the field)
Pin 1 Don't know about your 580 Case but a typical installation is as follows: Batt to key switch, to one leg of the idiot light. The other leg of the idiot light to pin 1. (pin 1 is used as initial excitation for the fields thru the idiot light)
For a test, via a jumper wire, put batt voltage in on Pin 1. It should initially excite the fields. Once initially excited, the alt should have output and be self exciting via the diode trio. Stop the unit? You will have to excite again.......
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
