1066 TA problem
Posted by DeWayne Utrup on January 12, 2015 at 09:46:10 from (216.227.55.31):
The TA on my 1066 slips or stops working on the low side after it warms up. Say after pulling the field cultivator for 30 min. or so. I typically pull the lever back on the ends and it will slip and sometimes stop all together. I want to make it correct. I borrowed an OTC hydraulic tester that appears very similar to the pictures I have seen of the IH Flowrater. I took a reading with the inlet attached to the orifice port on the MCV. With the orifice in place I have 3 gpm at 1200 psi. With the orifice removed I get 9 gpm at full flow. Both of these seem correct with the book so I believe the pump and MCV are good. Are there any other tests that I should perform before I take it apart and replace the TA? Thanks in advance.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
