Posted by Baelee05 on January 13, 2015 at 10:19:20 from (12.206.0.34):
In Reply to: Re: 1066 TA problem posted by Allan In NE on January 12, 2015 at 17:05:37:
The worst thing you can do for a TA is to use it as a brake. The TA was designed as a gear reduction to be used to pull thru a tough spot or just when you need to shift down a gear. Now, using it to turn at the ends isn't quite as bad as using it to slow down on the road when you are coming to a stop sign but it is still not ideal. The reason most TA's fail is because they are used improperly.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
1958 FORD RARE 4x4 801 TRACTOR, ELENCO/FRONT DRIVE, FRONTLOADER AND WEIGHTED REAR WHEELS, FIVE SPEED, LIVE PTO, GAS ENGINE, NEW REAR WHEELS AND TIRES, ENGINE RUNS.
[More Ads]
