Re: 1066 TA problem
Posted by ep on January 12, 2015 at 10:23:50 from (173.209.211.154):
In Reply to: 1066 TA problem posted by DeWayne Utrup on January 12, 2015 at 09:46:10:
If you have a hydraulic clutch assist, unhook it at the bottom of the MCV valve and install a 0 to 500 psi gauge, if it doesn't have assist, the port is at the very bottom of the MCV. You should have about 250 to 275 psi in ta and direct. Sounds like ta is bad. Good luck
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tractor Profile: Oliver 70 Row Crop - by Staff. The Oliver 70 was part of the "Fleetline Series" and was manufacturered from 1937 to 1948. The row-crop configuration could have either dual or single front wheels. The Oliver 70 was also offered in the standard, orchard and industrial configurations. The tractors were sold in Canada. An early advertisement states "Power when you want it - power when you need it - power to help put in crops when field conditions are right and time and help are limited. That's the power you'll find in an Oliv ... [Read Article]
