Re: Farmall 460 hydraulic woes continue.
Posted by pete 23 on November 12, 2014 at 16:18:19 from (173.87.8.9):
In Reply to: Farmall 460 hydraulic woes continue. posted by c. oliver teitz on November 12, 2014 at 09:26:52:
If that orfice is the problem the system will be staying on demand all the time and would actually work fine when you are lifting the loader or using any other hydraulic cylinder. The system would also get very hot. Actually the system would sound relieved when ever you used a cylinder with no or light load on it. They were .031 original and many drilled to various sizes, .040 being a good start. I would suspect you have a suction leak at the pump suction tube seal. That is the seal right at the pump. They get hard so they don't seal or damaged when installing pump or not adjusted to proper length.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Product Review: Storm Covers - by Staff. We recently had a chance to try out the new Storm Cover for the Ford 9N, 2N and 8N tractor that is now being re-introduced to a new generation of Ford N-Series tractor owners. Originally produced more than 40 years ago, it is now enjoying a reproduction run that has been licensed by the Ford Motor Company. An original storm cover was used for the pattern, and this reproduction cover is indeed exactly as the original (of which we had previously only seen pictures of in miscellaneous old sale ... [Read Article]
Latest Ad: Looking for a minneapolis moline zts [More Ads]
