Posted by c. oliver teitz on November 12, 2014 at 09:26:52 from (74.44.238.162):
The tractor has the extended industrial style filter housing with an industrial filter. Fluid level is well above full. It isn't a freezing issue as it was doing it before the cold weather set in. The problem I'm having is the hydraulics scream when first started and get slightly better when it warms up. The loader will lift plenty of weight. The hydraulics work better/faster at an idle than they do above 1200 RPM or so. Above that they pulse and scream like they are starving for oil. After an hour or two of hard use the hydraulic filter cover is only 70F or so if the weather is 20F-30F outside so nothing is getting too hot by any means either. I forget the name of the thing that has the screen and check valve in it but the screen has been removed. The tractor has sat for a couple of years since I did that though. Any ideas for me?
Today's Featured Article - Product Review: Storm Covers - by Staff. We recently had a chance to try out the new Storm Cover for the Ford 9N, 2N and 8N tractor that is now being re-introduced to a new generation of Ford N-Series tractor owners. Originally produced more than 40 years ago, it is now enjoying a reproduction run that has been licensed by the Ford Motor Company. An original storm cover was used for the pattern, and this reproduction cover is indeed exactly as the original (of which we had previously only seen pictures of in miscellaneous old sale
... [Read Article]
Latest Ad:
Looking for a minneapolis moline zts
[More Ads]
