Posted by jimb2 on June 18, 2013 at 19:05:31 from (99.241.76.141):
In Reply to: 574 parking brake posted by Yellott Canby on June 18, 2013 at 16:49:38:
Hi YC, someone has driven the 574 with the parking brake on and stripped all the brake material off the parking brake band and may have also damaged the parking brake drum. This is a common problem with the 74 series tractors. The newer series had a flashing park brake light on the dash. The hydraulic filter is probably clogged with brake band/drum bits but the problem could have occurred 30 years ago and the band/drum bits have been filtered out years ago.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit
... [Read Article]
Latest Ad:
WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac
[More Ads]
