Posted by Yellott Canby on June 18, 2013 at 16:49:38 from (67.54.206.69):
Hello, I was wondering if there is more than one adjustment on a 574 parking brake. Mine won't hold at all when pulled up. I tightened the cable by tightening the jam nuts right behind the handle. Got the handle so tight that I could no longer pull it up to the first notch but still had no parking brakes. The foot brake on the right side works but the left does not. Will try and bleed it later tonight but figure that should not affect the parking brake. Any ideas. Thanks, YC
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit
... [Read Article]
Latest Ad:
WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac
[More Ads]
