Re: 574 parking brake
Posted by jimb2 on June 18, 2013 at 20:32:20 from (99.241.76.141):
In Reply to: Re: 574 parking brake posted by Yellott Canby on June 18, 2013 at 19:35:25:
The parking brake band and drum are under the seat on the drive shaft to the diff. The foot brakes are on the final drive assembly and the axle housing has to be remove to replace the leaking O-rings on the brake piston. Before replacing the O-rings on the foot brakes, check the hydraulic brake lines on top of the transmission by removing the sheet metal cover over the transmission. Also check for leaking brake master cylinder.
Park brake band replacement requires removing fenders, fuel tank, seat and deck plate and 3pt rock shaft housing. According to my brother's local CaseIH mechanic, replacing the park brake band with a damaged drum will not solve the problem and to replace the drum is many $$ more.
JimB
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
