Re: LED lights and flasher problem
Posted by Janicholson on December 07, 2012 at 16:12:02 from (96.24.99.126):
In Reply to: LED lights and flasher problem posted by Dean Olson on December 07, 2012 at 16:03:28:
The flasher you need is not load dependent, it is timed not based on current draw. Jim
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
