Re: LED lights and flasher problem
Posted by sflem849 on December 08, 2012 at 05:47:24 from (69.197.84.39):
In Reply to: LED lights and flasher problem posted by Dean Olson on December 07, 2012 at 19:13:31:
It is pretty common. You see it most often on trucks/cars that people convert to LED lights. Happens every time.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
