LED lights and flasher problem
Posted by Dean Olson on December 07, 2012 at 16:03:28 from (98.196.66.64):
I have a 53 Super H that I've converted to 12 volt. I wired it up with led lights mounted to the fenders and installed a heavy duty mechanical flasher unit and after market light switch. It wouldn't flash till I hooked it up to the trailer with conventional bulbs. I suspected that the flasher needed more amperage to operate. I put the old lights back on and ran it like that till it burned up the fuse holder. The fuse holder was a cheap one from the auto parts store. The 20 amp fuse didn't blow.
I ordered an new oem fuse holder and switch. I put a 15 amp fuse in. With the tractor lights it worked perfect for over an hour. I then hooked up the trailer and the 15 amp fuse lasted about 20 minutes. Trailer has 3 marker lights on each side and 4 tail lights.
I decided to put all led lights on the trailer to get the amperage down. Also put the led lights back on the fenders. I got the lights from a heavy truck parts store. I talked the the parts guy and he recommended an electronic flasher unit. He assured me it would work with led lights.
I got everything all hooked up and working, on tractor, but would not flash. If I put a test light in the trailer wiring pig tail on the tractor it flashes. Hooked up the trailer and all lights work but no flash. I put a non led tail light back in and it flashes.
I still think I have a problem with the flasher unit ????
Any insight would sure help.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
