Re: Re: Re: Super M 50 yr old fluid
Posted by Jerry on September 28, 2000 at 19:17:34 from (208.16.251.111):
In Reply to: Re: Re: Super M 50 yr old fluid posted by Andy Martin on September 26, 2000 at 08:19:19:
Read the comments on trani fluid color, had to check, it was black/brown and the consistancy of molasses at the rear drain and molasses in january at the small plug behind the clutch housing, anybody have any thoughts ?
PS: is 90wt gear oil the recommended fluid ?
Post A Followup
: Re: Re: Re: Re: Super M 50 yr old fluid
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
