Re: Re: Re: Re: Re: Super M 50 yr old fluid
Posted by Jerry on September 29, 2000 at 11:39:55 from (208.163.64.29):
In Reply to: Re: Re: Re: Re: Super M 50 yr old fluid posted by Andy Martin on September 28, 2000 at 20:22:57:
I agree.
I was thinking of using diesel fuel to flush cause that stuff is like glue !
No one around here carries that much 90 wt, would have to special order, 80/90 is in stock, any thoughts on if that would be ok?
Post A Followup
: Re: Re: Re: Re: Re: Re: Super M 50 yr old fluid
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
