Posted by jimb2 on December 13, 2011 at 15:43:18 from (174.115.9.174):
In Reply to: 574 power steering posted by Kevin Roberts on December 11, 2011 at 18:52:05:
Hi Kevin, Since the tractor steers by using the Danfoss steering valve hand pump in the steering column, I still suspect the hydraulic supply to the steering valve is low. Quick test if tractor has remote hydraulic outlets, with nothing connected to the remote outlets, pull the remote hydraulic lever while trying to turn the steering wheel, you should also hear the hydraulic relief valve buzzing. If the PS works then the priority valve is stuck. Sometimes the shock to the hydraulic system by pulling the remote lever frees the priority valve. The test would be to pressure test the PS hydraulic supply line, should be about 1500 psi. I believe PS hydraulic supply line comes out of bottom left of MCV valve. Re PB, the PB requires only a small amount of hydraulic oil to work.
Today's Featured Article - Grain Threshing in the Early 40's - by Jerry D. Coleman. How many of you can sit there and say that you have plowed with a mule? Well I would say not many, but maybe a few. This story is about the day my Grandfather Brown (true name) decided along with my parents to purchase a new Ford tractor. It wasn't really new except to us. The year was about 1967 and my father found a good used Ford 601 tractor to use on the farm instead of "Bob", our old mule. Now my grandfather had had this mule since the mid 40's and he was getting some age on him. S
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
