Re: 574 power steering
Posted by jimb2 on December 14, 2011 at 13:47:35 from (174.115.9.174):
In Reply to: Re: 574 power steering posted by Kevin Roberts on December 14, 2011 at 08:02:50:
Kevin,
pulling the remote, should causing a buzzing sound and pull the engine RPM down. If it doesn't buzz then either enough hytran fluid is getting to the hydraulic pump or the pump is weak but if the 3pt will pickup a heavy implement like a plow then the pump should be good.
JimB
