Very few cranks are threaded. You have removed the steering sector correct. Use a bearing seperator behind the pulley and a good three jaw puller and it will cone off. They are a pressed fit. Check to see you dont have a set screw as some did.I made an installer to replace it as driving could break the pulley and heat wont doo the seal any favors.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
