Removing Front Pulley on 47 B
Posted by gurneejoe on November 27, 2009 at 15:27:25 from (205.188.116.73):
I finally got started on disassembly of the B today and am down to the front pulley. I am trying to figure out what thread size the front of the crank has. I have gotten the impression from the archives that this is generally not an easy task. If I need to get it cherry red will it damage the crank hardness? Can I just run the puller against the crank with a washer?
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
