Re: Removing Front Pulley on 47 B
Posted by El Toro on November 28, 2009 at 07:31:54 from (74.103.74.58):
In Reply to: Re: Removing Front Pulley on 47 B posted by gurneejoe on November 28, 2009 at 04:14:35:
Those are wet sleeves and you can use a piece of of 2 X 2 oak and a hammer and drive out the rod, sleeve & piston. Then use an acetylene torch
to heat the sleeve to free the piston. Be sure to clean that block area where the old sleeve seals are. New sleeve/piston kits are readily available. Hal
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
