Re: 400 dies,fires right back up?
Posted by Bob O2 Martin on September 11, 2009 at 17:43:16 from (71.7.67.73):
In Reply to: 400 dies,fires right back up? posted by Too Far Gone on September 11, 2009 at 15:32:04:
I think I would try to determine if it's fuel or spark that's causing the problem.
When it dies, I would check for spark coming out of the coil tower.
I suspect the problem is either in the condenser or the coil. The coil in particular.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
