400 dies,fires right back up?
Posted by Too Far Gone on September 11, 2009 at 15:32:04 from (67.221.197.94):
Dang 400 has been throwing these little dying fits for awhile now.It's just like you shut the key off.Sometimes it acts short of fuel and pops and snorts trying to re-start,but I think it temporarily floods itself when it dies at full throttle on the plow and pumps a load of gas in there, its got unrestricted fuel flow.Ive had carb off 3 times.I use it everyday.It always re-fires,then it might run 2 minutes or 2 hours before it throws another fit.Ive had the cap off the points turning it over,and I kinda think maybe points and condenser,they are 6 years old anyhow,and the coil is original Farmall coil.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
